Activity › Forums › Apple Final Cut Pro › Creating Luts
  • Creating Luts
    Posted by Joe Lukus on July 24, 2017 at 12:47 am
    I posted this in color grading and give it got a response so I thought I would post it here..
    Probably very simple answer, but was curious…
    OK you see a lot of information about downloading luts and applying them, but how can I create a lut to export and share??! I am using Final Cut Pro and I have color finale and I know I am able to create presets to use on other clips just like with Final Cut Pro Board… but are you able to output a lut file from That? because that is all a lut is correct? Just a preset color grading? So I guess how do I get my saved presets into a lut file to be used as a “lut”?
    Or I’m I missing something here!?
    Thanks!!
    Joe Lukus replied 9 years, 2 months ago 4 Members · 5 Replies
  • Noah Kadner
    July 24, 2017 at 2:03 am
    Yeah you can create your own LUT but keep in mind they are intended to create a specific effect using a specific source camera. Just applying any LUT to any footage will result in wildly different results. It’s not so much about making/sharing styles. It’s about deriving a certain specific final look from footage originated from a specific camera/source. I.e. applying an ARRI Alexa LUT to a Canon C300 is not going to make it look like footage from an Alexa, instead it will produce unexpected results. Think of a LUT as a translator from source to final look.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Jeff Kirkland
    July 24, 2017 at 8:43 am
    Color Finale can’t export LUTs. I think you could probably copy presets you save in the Finder and share them with other Colour Finale users but that’s about the extent of it.
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Marco Feil
    July 24, 2017 at 3:14 pm
    You can generate LUTs with LUT Generator. From any app, doesn’t matter – if you can import and export PNGs, you can generate a LUT.
    Basically you grade your image, apply the same grade to a special image, export it and convert it with LUT Generator to a cube LUT.
    You could grade something in Lightroom and export the grade to FCPX. Or export a Color Finale and Color Board grade to Davinci. I guess it’s not 100% accurate but it works really good.
  • Jeff Kirkland
    July 24, 2017 at 7:40 pm
    Hadn’t come across that app before. Looks promising – I’ll have to have a play with it.
  • Joe Lukus
    July 25, 2017 at 3:39 pm
    Thanks guys!!
    That’s what I was wondering how to actually creat a Lut! So looks like that Lut generator is what I need… I also saw that I guess you can create them in Lightroom also… but just wasn’t sure if the file extension would work/be the same and carryover like it is suppose with correct colors etc…
    But it sounds like that’s how you do it with still pictures and them create a file which I guess is a standard LUT file format that stays constant and works across programs, video and stills…
    Thanks our FCPX forum is way better than the others! Lol
    You guys the best!
