Activity › Forums › Adobe Photoshop › creating Letterbox Mattes in Photoshop for FCP HD Layoff – HELP!
  • creating Letterbox Mattes in Photoshop for FCP HD Layoff – HELP!
    Posted by Lisa Rolley on April 30, 2009 at 9:10 pm
    Hey friends,
    I tried doing a search on this on the forum but no luck and i need to layoff by EOD!!…so here goes:
    I have been asked to layoff an HDCAM tape with multiple types of Letterbox Mattes so i need to create these in Photoshop and obviously have alpha info where picture would be and black bars elsewhere for the ltrbx.
    I have never had to do this and am not very strong with PS – can anyways quickly explain to me how to do this in photoshop for one of the ones i have to make and then obviously i will understand how to make the rest.
    i did the math already so i know what frame sizes they need to be i just dont know how to properly make this in PS and export for use in FCP.
    Here are the HD sizes i need for creating Letterbox Mattes:
    1920×817
    1793×1080
    1920×1038
    1436×1080
    Thank you for any help you guys can provide
    Best
    Lisa
    Keith Carmichael replied 17 years, 4 months ago 2 Members · 1 Reply
  • Keith Carmichael
    May 12, 2009 at 9:51 pm
    Yeah, that’s annoying.
    You know FCP has a whole host of widescreen mattes in the video filters category, right?
    Effects>Video Filters>Matte>Widescreen. You can select different dimensions once you apply the filters.
    But if you need an odd size or something, here are steps:
    -Create a new photoshop document that’s the SIZE OF YOUR FCP SEQUENCE
    ——photoshop has presets for most frame sizes under Preset>Film and Video
    ——choose background contents “transparent”
    -Edit>Fill the background with black
    -View>clear guides to clear the title safe guides that are there
    -View>New Guide to make two horizontal guidelines for the boundaries of your letterbox
    -Make sure View>Snap is checked
    -Use the marquee tool (top tool, or press M) to select the area between the guidelines and go to edit>clear.
    The picture area should now be gray checkerboard, indicating transparency. If the picture area is white, it just means you chose a white background when you created your document. You have to go to Layer>New>Layer from Background and try the operation again.
    Then save as PNG and throw it into FCP. You could make a black and white image and use it as a matte but… why bother. This way’s fine.
