Activity › Forums › Apple Final Cut Pro Legacy › Creating Letterbox-How To?
Posted by Richard Boddington on December 2, 2006 at 4:51 pmHi,
Can some one tell me how to create a letter box in FCP 4?
I don’t want to squish the video, I just want to lay back bars top and bottom of 4X3 video to hide the VTC.
What are the steps in terms of menu>next step>next step>next step.
Yes, I checked the manual and the help. But all I’m getting is explanations on making 4X3 into 16X9, that’s not what I want.
RichardTony replied 19 years, 9 months ago 3 Members · 6 Replies -
Jerry Hofmann
December 2, 2006 at 4:57 pmApply the Widescreen filter to the clip or nested sequence. It’s found in the Matte submeu.
Jerry
Richard Boddington
December 2, 2006 at 6:23 pmThanks Jerry, but I can’t find the Matte submenu, where is that?
Richard[Jerry Hofmann] “Apply the Widescreen filter to the clip or nested sequence. It’s found in the Matte submeu.
Jerry”
Tony
December 2, 2006 at 6:45 pmvitc timecode is outside of the active video area and is usually only visible in underscan mode on your monitor.
So there should be no need to hide it.
Or are you referring to burned in timecode on screen as in visible timecode?
Is the material a window dub or footage that contains timecode reference? Why the need to hide it are you using it for an offline and later will replace with the original source material?
Tony Salgado
Richard Boddington
December 2, 2006 at 7:18 pmYes I need to hide it. The VTC is over the black area at the bottom of frame from SD dubs made from a HD master. I need to cut a web trailer from the footage and I want to cover the TC numbers. Plus I have to LTR box the animated title I built so it all looks consistant.
But how to do it???????? That is the question??????
Imagine you’re explaining this to your 95 year old grandmother, start with, turn on computer…..
I need to where exactly these options are you refer to.
R,[tony salgado] “vitc timecode is outside of the active video area and is usually only visible in underscan mode on your monitor.
Tony Salgado
Richard Boddington
December 2, 2006 at 8:33 pmNever mind, I found a how to on this at LAFCPUG.
Richard -
Tony
December 4, 2006 at 3:29 pmok grandma,
1) open up FCP text manual
2) read chapter of contents find section on applying a matte
3) read specific chapter, test out new knowledge
4) enjoyor
1) turn on computer
2) boot up FCP
3) Go to help
4) type in matte or letterbox
5) read, learn, enjoyor
1) turn on computer
2) boot up web browser application
3) navigate to Google or other search engine
4) type in “creating a matte in FCP”
5) Read, learn, enjoySo you see grandma it’s so easy when you learn how to conduct educational research.
Now can you please whip me up a sandwich all that research made me hungry?
Tony Salgado
