Activity › Forums › Adobe After Effects Expressions › Creating layers with sequential numbers
  • Creating layers with sequential numbers
    Posted by Evan Schafer on June 11, 2008 at 5:41 pm
    Is there an expression out there that could create a new layer with the number “1”, create a new layer with “2” etc…up to 350? I need to generate these numbers for use in Photoshop eventually so I would save as a PSD, but I cannot figure out how to do it in PS. I’m using CS3, by the way. Thanks!
    Jon Date replied 15 years, 10 months ago 3 Members · 4 Replies
  • Dan Ebberts
    June 11, 2008 at 6:38 pm
    With an expression, you could just create a text layer, add this expression to the source text:
    index
    And duplicate the layer 349 times.
    Or, create a comp and run a script like this:
    var n = 350; // number of layers to create
    var myComp = app.project.activeItem;
    var myTextLayer;
    for (var i = 350; i > 0; i–){
    myTextLayer = myComp.layers.addText(i);
    Dan
  • Jon Date
    December 6, 2010 at 4:51 pm
    Dan could you help me with a script that does the duplication of the selected Comp in your projects panel.
    I need to duplicate a comp 300+ times and have a comp “1”. I need comp “2”, “3”, “4” etc all the way to 300+ but am struggling to get the correct statements to get it done in the same way you wrote the Layers script above.
  • Dan Ebberts
    December 6, 2010 at 5:45 pm
    Like this:
    var myNewComp;
    for (var i = 1; i <= 300; i++){
    myNewComp = myComp.duplicate();
    myNewComp.name = "" + (i+1);
    Dan
  • Jon Date
    December 6, 2010 at 5:50 pm
    Thanks Dan!!
