Activity Forums Web Design (WordPress, Joomla, etc.) Creating HTML e-mail
  • Posted by Leor Brenman on August 3, 2007 at 3:22 pm
    Hi All,
    What is the recommended e-mail client for creating a simple HTML e-mail.
    Actually, all I am trying to is have an image (that is hosted on a web site) embedded in an e-mail. I use the img src tag and it displays correctly but Outlook 2007 does not provide a means for embedding HTML tags. Windows LiveMail has a stationery feature which looks like it works, but the image actually gets embedded in the e-mail as an attachment.
    I get HTML e-mails all the time. I wish I knew what e-mail program they use to create the e-mail.
    Any help would be appreciated.
    Best Regards,
    Leor
    Jaykilla replied 19 years ago 4 Members · 4 Replies
  • Leor Brenman
    August 3, 2007 at 5:26 pm
    OK. I did more research and find that using Dreamweaver for the HTML creation and Mozilla Thunderbird for creating an e-mail is a good solution.
    The problem I am having is that the images that I host and reference using img src tags are appearing as attachments in the received e-mail. I am trying to create an e-mail marketing campaign where the e-mail looks like a web page (actually is a web page) and is only viewable if the viewer is connected to the internet. This will keep the e-mail lightweight but image rich.
    Any ideas?
  • Matt Sonberg
    August 14, 2007 at 4:57 pm
    If you happen to figure this out I’m trying to do the same thing and haven’t had any luck finding help on the web thus far.
  • Abraham Chaffin
    August 14, 2007 at 5:20 pm
    For the most part Email client programs like outlook or thunderbird don’t want you to use their programs to send out newsletter style emails. They want to cut back on the amount of spam that gets sent through their systems. You need to buy a 3rd party program that is specifically designed for html mailings or newsletter mailings.
    Try googling
    html email software
    or
    newsletter email software
    Hope this helps.
    Abraham
  • Jaykilla
    August 28, 2007 at 1:20 pm
    You could actually do this in PHP quite easily, but if you don’t know php here is a little trick that works. You have to use hotmail though. When you log into your account compose a message and simply type in html your message i.e.
    When you send out your message your images will appear in html and then you can send the email to your clients. No third party software necessary.
    Here is the php link if you want to go this route, I have used both methods and they work the same.
    https://www.php.net/mail
