Activity Forums Compression Techniques Creating HD MPEGs
  • Creating HD MPEGs
    Posted by Sanjay Chalisey on March 5, 2008 at 11:25 am
    Hello,
    I’ve been asked to create HD MPEGs based on the following dimensions:
    Pixel Dimensions: 1920 x 1080
    Frame Rate: 25fps
    Bitrate: 36 mbit/s CBR
    Profile: Main
    Level: High
    VBV Buffer Size: 488
    Closed GOPs
    N Value (Number of Frames in GOP): 15
    M Value (Number of Frames Between Anchor Frames): 3
    Sequence Header Interval: Each GOP
    Video Encode PID: 16
    If you look at the settings, Compressor (as far as I know) cannot achieve this. For example, If I choose the MPEG-2 or the HD MPEG presets and then try to adjust these (after duplication), I cannot change the bitrate settings from VBR to CBR as an example.
    Would be grateful if another encoding application can be recommended for the apple mac (does Pixel Tools have a mac version of their MPEG encoding software for example?).
    Many thanks in advance.
    Sanjay Chalisey
    7 Continents Productions
    Del Chapple replied 18 years, 5 months ago 4 Members · 4 Replies
  • Daniel Low
    March 5, 2008 at 12:50 pm
    Take a look at this, it does what you need:
    https://www.digigami.com/megapeg/features.php
    You might also want to check out Episode Pro from Telestream.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Sanjay Chalisey
    March 5, 2008 at 2:12 pm
    Thanks Daniel.
    Will update you once I’ve made progress on this.
    Appreciate the help.
  • Rich Rubasch
    March 6, 2008 at 1:09 am
    Somehow I could do this…I don’t recall what I did. I think it depends on which preset you start with, duplicate it and then adjust the settings. I had to make a similar MPEG and at first I could not change the VBR setting…..later I tried again and I could select CBR no problem.
    Again it depends on which preset you start with (can’t recall) and how you change the settings.
    I loathe compressor.
    Rich Rubasch
    Tilt Media
  • Del Chapple
    March 11, 2008 at 3:18 am
    You are probably going to have to invest in another program. I’m sure episode will do this but does episode do hd..? I use Rhozet which is a pc program, you can pretty much make anything m2t’s to flash etc, sound like you need a transport stream because of the pid but there is also a need for a audio program id..
    del
    you cant hear my inner voice scream… can you..?
