Activity Forums Maxon Cinema 4D Creating hair with square tip
  • Creating hair with square tip
    Posted by Slòóky Vøn slük on October 29, 2015 at 3:41 pm
    Working on a few macro shots of synthetic turf and I cannot figure out a way to create square tips. The default hair uses a rounded tip. Tried using the thickness curve editor to make a sudden drop to zero, only to find it creates more of a triangle. Just do a google image search for “turf closeup” and you’ll see what I’m trying to achieve. Thanks in advance.
    Slòóky Vøn slük replied 10 years, 10 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 30, 2015 at 4:02 am
    Looks like the only way to do it is to generate geometry (Hair Object>Generate).
  • Slòóky Vøn slük
    October 30, 2015 at 12:31 pm
    Yes I believe you’re right. I had to make my own individual blade and use it as an instance. Slows things down a bit, which is what I was afraid of, but it looks great! Thanks for the reply.
