Activity Forums Creative Community Conversations Creating graphics in AE for FCP X
  • Creating graphics in AE for FCP X
    Posted by Chase Gardiner on July 12, 2011 at 10:00 pm
    Hey everyone,
    My issue is now that I have made the change over to FCP X my graphics are no longer nice and crisp. I have a bunch of intros, outros, nameplates, ect created in AE and exported using the animation codec, all these worked fine in FCP 7 but now come in slightly blurry. Can anyone shed any light on my issue here and help out? Also, I have tried matching the settings by exporting the graphics from AE as DV, DV50, Animation, ProRes422 and even MP4 just for the sake of trying.
    Screen shot from the AE project: https://i51.tinypic.com/30mslrc.png
    Screen shot from the FCP X project: https://i55.tinypic.com/fx6p36.png
    Thanks for the helps guys
    Robbert-jan Van der does replied 15 years, 2 months ago 5 Members · 9 Replies
  • 9 Replies
  • Tony Brittan
    July 12, 2011 at 10:50 pm
    Isn’t there a ProRes codec with alpha?
    Tony Brittan
    Island Shore Productions
  • Robbert-jan Van der does
    July 12, 2011 at 10:52 pm
    Hi Chase,
    Did you check your settings in the preferences?
    In the Playback section of the preference pane you can set the Playback Quality to “High Quality”.
    You might already have tried this, but it’s all I can think of right now.
    Kind regards,
    Robbert-Jan van der Does
    lighting cameraman/steadicam operator/editor
    WISIWYG (What I See Is What You Get)
  • Chase Gardiner
    July 12, 2011 at 10:59 pm
    No need for Alpha for this project, and I have tried prores 422 as well HQ, and LQ
  • Chase Gardiner
    July 12, 2011 at 11:01 pm
    Prefs were set to high quality when the screen cap was taken.
    Thanks for the reply though.
    July 12, 2011 at 11:08 pm
    One other thing to check maybe.
    When you select the clip, go to the inspector. Then the Info tab and at the bottom select “Settings View”.
    Here you can check if the field order settings match your project.
    There might be a mismatch.
    I had this the other day with XDCAM (SD) material that was shot progressive (PsF). My project was also progressive but the clips were interpreted as Upper Field First. The result was that I only saw half the resolution in the viewer. I had to set the field order to None.
    Kind regards,
  • Nick Toth
    July 13, 2011 at 12:23 am
    Looks like interlaced graphic in a progressive project. What are the project settings in FCP?
  • Bret Williams
    July 13, 2011 at 1:36 am
    Then why use animation?
    Can you screen shot the rendered QT file from AE? A screenshot of an Uncompressed frame in AE has no bearing here.
  • Chase Gardiner
    July 13, 2011 at 4:12 pm
    ahh thank you that was my issue! It was viewing lower field
    Thanks for the help everyone
    July 13, 2011 at 4:21 pm
    Glad you found it!
    Kind regards,
