Activity › Forums › Adobe After Effects › creating global clouds to outdo Andrew
Posted by Craig Wall on July 24, 2007 at 6:24 amI want to take Andrew Kramer’s totally cool globe tutorial and take it one step further. Whew, the air gets thin up here! Is it possible?
Does anyone know how to tweak something within the AE galaxy of possibilities and come up with the kind of clouds/atmosphere that you would see from space? Andrew animates the position of his atmosphere which is cool but I want it swirling and swooshing.
Then I thought of a displacement map with fractal noise as the displacement map but I quickly gave up on that. (Perhaps prematurely)
Of course I played with fractal noise alone as the atmosphere and perhaps I haven’t played enough with it. Certainly it creates clouds–but I haven’t seen any examples of how one would use that plug-in to create the swirly weather system you would see from space.
Suggestions?
Antony Buonomo replied 19 years, 2 months ago 5 Members · 11 Replies -
Antony Buonomo
July 24, 2007 at 9:43 amHi
This is a rough test I did for a recent production –
https://www.vertigo.co.uk/test/CameroonEstablishMap4.mov
(10mb)If you’re looking for something like this then I think it’s not hard. Start with fractal noise>Swirly/Linear on a white solid. Contrast high and Brightness low; these will control the amount of cloud cover you have.
Uncheck ‘Uniform Scaling’ and make width roughly 2x height; I used 163/83 but it depends on the size of your comp.
Animate the evolution.
Then play with the Twirl effect (in Distort menu) to make eddies and swirls.
Then wrap using CC Sphere, precomp and place over your globe with Linear Dodge blending.
I’m sure I have forgotten some things but I hope this helps a bit.
A
Mike Procunier
July 24, 2007 at 1:46 pmWhat about trying your Fractal Noise & add some swirling by experimenting with some of the Distort effects like Swirl, Liquify, Mesh Warp or possibly Puppet Tool? I’ve done some neat things with Puppet Tool, it has a lot of possibilities, even in non-cartoon applications.
Darby Edelen
July 24, 2007 at 5:42 pm[craigcow7] “Andrew animates the position of his atmosphere which is cool but I want it swirling and swooshing.”
Swooshing can be accomplished fairly easily and decently with Turbulent Displace or a Displacement Map. Swirling, as in a hurricane, would be more complicated. You can get a pretty good spiraling effect with Time Displace and a radial gradient. Then in order to make the interior of the hurricane move faster than the exterior you’d probably need to use Timewarp with a track matte (maybe the same radial gradient that you use for the time displacement).
I’ll work on this and see if I can get you a sample later today.
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Mike Clasby
July 24, 2007 at 6:09 pmHere’s a Cow tut for slow movements (swirly included):
https://www.creativecow.net/articles/quince_graham/liquify/index.html
Darby Edelen
July 24, 2007 at 6:15 pmSo it doesn’t look nearly as nice uploaded to Google Video, but you should be able to get an idea for the motion and what you try for yourself:
https://video.google.com/videoplay?docid=2337851367281373845
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Craig Wall
July 24, 2007 at 7:57 pmI very much appreciate the suggestions.
Darby you are doing well selling a hurricane but I am more challenged when the fractal density is much more dispersed.
Antony, you are certainly closer to my particular objective. What you have done certainly works and maybe that’s about the best one could achieve. Ideally I’d like a little more realism…like an ultra time lapse of real weather coursing over the planet.
Darby Edelen
July 24, 2007 at 8:25 pm[craigcow7] “Darby you are doing well selling a hurricane but I am more challenged when the fractal density is much more dispersed.”
If you look at images of the earth from space you’ll find that clouds obscure much of the earth and that, while there are some wispier clouds, there isn’t really much low density cloud cover visible.
https://akvis.com/img/examples/chameleon/earth-in-sky/image-earth.jpg
Looking at reference material I would recommend creating a series of cloud systems (pre-comps) that circle the globe slowly at slightly different rates. You could definitely use a subtle evolving distortion mesh (as has been suggested previously) to create the impression of currents.
I think it’s a fairly large undertaking, but that you can do a very good job of it if you put the time in.
Darby Edelen
DVD Menu Artist
Left Coast Digital
Aptos, CA -
Craig Wall
July 24, 2007 at 10:21 pmPerlin Noise is a powerful technology and I have a (little) understanding of it’s principle.
Clouds like this are indeed just another type of fractal noise…it’s trying to understand how to manipulate the variables to achieve the desired effect.
I also am intrigued more with the liquify effect. I was inspired to realize there is more under the hood with that little baby than you would guess from just the name.
I’ll let you all know if i come up with anything!
Mike Procunier
July 24, 2007 at 10:27 pmCheck out Aharon Rabinowitz’s new tutorial on Using Puppet Tool With Particles. He creates some neat looking swirly smoke that might be up your alley.
Craig Wall
July 25, 2007 at 3:30 amThanks, Mike_P
When I watched that tute the other day I kept thinking of how it would have been easier had Aharon used Bezier Warp.
(Not that I am not almost-always in awe of Mr. R’s tutes, believe me!)
My hunch is that particle systems won’t be the trick with this treatment. Thanks, though.
