Activity Forums VEGAS Pro Creating first DVD using Full HD (Export Settings)
  • Creating first DVD using Full HD (Export Settings)
    Posted by Rob James on September 6, 2011 at 5:24 pm
    Hi Guys, just a quick question before I hit the Render button. I’m making my first DVD with Full HD footage. In Vegas 10, my raw footage shows as 1920x1080x12, 29.970 fps.If I want this footage to play at the highest possible resolution from a DVD player, should I be exporting to Main Concept MPEG-2, Template HDV 1080-60i or should I be choosing DVD Architect NTSC video stream. Since I will be Authoring this project in DVD Architect 5.2 will it need to re-render these files? Trying to save myself a little bit of work and time, and still wind up with the highest resolution I can. Thanks in advance, for any and all advice.
    Rob,
    https://www.robjames.net
    P.S. I should add that this was shot with my Sony HDR-PJ10 at 1920x1080x12, 29.970 fps 60p, which is the highest resolution of this camera, if I’m mistaken. If that has any bearing on your answer.
    Rob James replied 15 years ago 2 Members · 3 Replies
  • Rob James
    September 6, 2011 at 7:28 pm
    I hit the solution button by accident, so could a Mod please remove it? Or I may never get an answer. I thought the button was to find a solution, not state that it was solved.
    Rob,
  • James Wilhelmi
    September 7, 2011 at 4:07 am
    For DVD you want to use MainConcept MPEG-2 and then use the NTSC widescreen video stream template. Then export your audio separately using the Dolby Digital AC-3 Pro setting. Name both files the same and when you import the video file into DVDA, the audio should follow automatically. If you have a BluRay burner and are exporting for BluRay then use the BluRay 1920×1080 60i template. Hope this helps.
    James
  • Rob James
    September 9, 2011 at 3:51 am
    James, that helped immensely………..a very succinct, straightforward answer. Thank you. Going to save that in Notepad form, for my records,thank you Sir.
    Rob,
