Activity › Forums › Adobe After Effects › Creating Faux Hair Edge-Effect form Puppet-Pined Layer
  • Creating Faux Hair Edge-Effect form Puppet-Pined Layer
    Posted by Aubrey Boles on July 5, 2016 at 10:15 pm
    I’ve got an IK rig, using Shape Layers Puppet Pins linked to null objects parented to various parts of a creature’s skeleton.
    https://imgur.com/W1Olbuh
    I want to make the edges rough, roughly similar to hair. This doesn’t need to be particularly accurate, as the image will be displayed behind some cloth (Giving the impression of a shadow passing behind the cloth). The Roughen Edge effects would be fine if the layers where not animated, but the shimmering the effect causes doesn’t look as good as I would like. I’ve tried using the CC Hair effect, but to no avail. Anyone have any ideas?
    (The rig consisted of a skeleton rigged with DuIK, with Puppet Pined shape layers acting as musculature. I plan on using this “hair-effect” on each of the relevant muscle layers to create the idea of short hair.)
    View post on imgur.com
    Aubrey Boles replied 10 years, 2 months ago 1 Member · 1 Reply
  • Aubrey Boles
    July 6, 2016 at 5:12 pm
    I just talked with a friend of mine, and he recommended I switch the order of effects to have the Roughen Edge” before the puppet pin. That works pretty well for most of it. He also pointed me to this: https://aescripts.com/smart-precomposer/ to precompose the shape layers.
    I figured I’d share the info here for others.
    -Aubrey
