Activity › Forums › Apple Final Cut Pro › Creating Events
  • Creating Events
    Posted by Jason Smith on November 25, 2011 at 5:11 pm
    I’m currently working on a documentary in FCPX and am attempting to determine best practices while ingesting footage, logging material, creating keywords, favorites, etc. I’m wondering is there any reason not to ingest all of my footage as one event? I would think that would create ease for the keywords. Is there a limit to how much material a single event can contain? What problems might I run into?
    Jason Smith replied 14 years, 10 months ago 2 Members · 4 Replies
  • Kevin Patrick
    November 25, 2011 at 7:04 pm
    [Jason Smith] “ingesting footage, logging material, creating keywords, favorites, etc. I’m wondering is there any reason not to ingest all of my footage as one event? I would think that would create ease for the keywords. Is there a limit to how much material a single event can contain”
    I’m not sure what FCP X’s limits are, but I have a project that consists of:
    One Event
    1,965 items in the Event
    1,881 clips in the Event
    61 Keywords
    23 Projects (used as Sequences)
    All the clips are XDCAM EX files. I used Sony’s XDCAM Browser to copy the clips off the memory cards to my computer and XDCAM Transfer to re-wrap the files to *.mov. Then I simply imported the files into FCP X. All of the media is referenced, nothing is copied or moved to the FCP X Event folder.
    I used Keywords to organize everything. I have only one folder to hold all the media in 8 different Keyword Collections. I sort of used these 8 Keywords like 8 Events. At first I considered creating 8 different events. But, I decided to use 8 Keywords instead of 8 unique Events.
    I would select the appropriate clips and assign one of the 8 Keywords to them. I dropped them all into a single folder. Then, I would scrub through all the clips assigning additional Keywords as I went. This is where all the organization of Keywords really worked great, since I could then further filter any other keyword set by entering one of the main 8 Keywords into the Event Browser’s search field. (I realize this either makes sense, or I’m doing such a poor job explaining what I did, it makes no sense at all)
    The use of Keywords was great for organizing. I don’t think there would have been any advantage to having more than one Event. In fact, I think it would have made things more complicated. I probably would have wound up combining Events. Plus, when I launch FCP X, it loads the single Event and all the necessary media is there for any of the various Projects I was working on. This entire “project” was broken down into 23 actual FCP X Projects.
    I never used Favorites. Not really sure why though. I found Keywords to work fine. Occasionally I had Keywords overlapping in a clip, which you can’t do with Favorites.
    Scrubbing through all these clips and assigning Keywords was very fast and efficient. No dragging and dropping. Skim through a clip, mark In/Out and assign one or more Keywords, FCP X drops each In/Out reference into the appropriate Keyword Collection.
  • Jason Smith
    November 25, 2011 at 8:44 pm
    Many thanks. Questions:
    1. How did you ingest without creating an event?
    2. Why did you do this?
  • Kevin Patrick
    November 26, 2011 at 12:07 pm
    [Jason Smith] ” How did you ingest without creating an event?”
    Sorry, guess I wasn’t clear enough.
    I do have one, single Event. I did all my work on this one Event. All the clips were imported, as files, into this Event. Then I used Keywords to organize everything.
    Since all the medias was going to be used for a single output, I didn’t see a need to use more than one Event.
  • Jason Smith
    November 26, 2011 at 8:53 pm
    Many thanks, Kevin! If you have any other ingesting/organizing tips for clips, I’m all ears. Again, thanks!
