Activity Forums Adobe Illustrator Creating dynamic dots
  • Oscar Polanco
    August 19, 2024 at 11:16 am
    I would recommend you to do that effect using the blend tool in Adobe Illustrator. That way you can create the transition maybe in 3 steps from small circle to big one and vice-versa, and the blend tool will create automatically the blending based on the specified steps between each one of them. Then you can create multiple lines of blending changing the size of the main dots.
    You can find a tutorial here about how to use the blending objects tool in Illustrator:
    https://helpx.adobe.com/illustrator/using/blending-objects.html
  • Joel Bellagamba
    August 28, 2024 at 9:59 pm
    That’s a great suggestion from Oscar! The blend tool in Adobe Illustrator can definitely help you create those dynamic dots.
