Activity Forums DaVinci Resolve Creating Database Issue
  • Sean Kapleton
    January 4, 2011 at 3:13 pm
    any update on this – i have seen this error at a studio i worked at the other week and was curious what the easiest fix would be for this error?
  • Paul Jay
    February 7, 2011 at 4:54 pm
    The solution is given in previous posts.
  • Sean Kapleton
    February 7, 2011 at 10:10 pm
    thx got my answer a month ago but cheers anyways!
  • Hugo Perez
    September 3, 2012 at 11:30 pm
    Let me start by saying that I am not a professional, I merely installed Resolve Lite for learning purposes, and would not be able to answer any technical questions. I came across this database problem when first launching Resolve. I found the same solution on several threads involving the use of Terminal. As Daan Hermans said, some of us may not know how to use terminal. His solution worked for me. Here is what I did.
    1. Rename the folder “/Library/PostgreSQL” to “/Library/PostgreSQL.bad”
    2. Reinstall Resolve (There is NO need to uninstall first)
    3. Relaunch Resolve and it should now work.
    Again, this solution worked for me, without the need to run commands in Terminal (for those of us who are unfamiliar). Thanks Daan.
    By the way I am on a 2012 Non-retina MacBook Pro 15 High-Res
    Hugo Perez
Page 2 of 2
