Activity › Forums › Adobe After Effects › Creating damaged video look
  • Creating damaged video look
    Posted by Ryan Adams on July 30, 2008 at 4:36 am
    Trying to create the look of damaged digital video, where the video briefly becomes slightly mosaicked. If any one know of a plugin or a simple way to do this it would be of much help. Also looking for a way to give the video that distorted signal look where it becomes all wobbly.
    Ryan
    Corbin Gross replied 18 years, 1 month ago 5 Members · 5 Replies
  • Scott Novasic
    July 30, 2008 at 7:18 pm
    the plug in set “DAMAGE” by digieeffects is EXACTLY what you need for this. I wrote a review of the software on the net. (google damage review) they are great tools and affordable!
    good luck
    SuperNova
    Animation & Visual Effects
    Scott Novasic
    Los Angeles Ca
    web:https://web.mac.com/finaleffects
  • Peter Mcauley
    July 30, 2008 at 9:51 pm
    There is also a filter in the Boris Continuum Complete package that is dedicated to this task. The filter is called “Damaged TV” and is available for all hosts. You can download a free two week trial version of the filters from here http://www.borisfx.com/downloads. After the trial period has expired, the filters will continue to render but will add an X watermark to the image. You can remove the X watermark by purchasing a license.
    I hope this helps.
    Peter.
  • Scott Novasic
    July 30, 2008 at 10:29 pm
    cinelooks film damage plug in is one of my favorites.
    But the BEST deal is Damage. $99 for 4 individual plug ins dedicated
    to television damage right down to the source level, different video signals and a variety of control settings. freezing, cable digital blockiness, and much more.
    I like boris stuff as well, just much more expensive, and not the
    total focus on the look you are going for, that the 4 damage effects
    can give you, plus, they render in realtime and FASTER. Im sure you can download a demo as well, or like I said, check out the review of Damage online, I go into much more detail.
    no, I do not work for digieffects 🙂
    good luck
    SuperNova
    Scott Novasic
    Los Angeles Ca
  • Jerry Renes
    July 31, 2008 at 11:49 am
    If you don’t want to buy plugins at the moment. It might be a good idea to study examples of this effect. Like on Youtube you can find several “damaged video” examples. Take the Cloverfield movie trailer.
    I think it would be possible to recreate these effects just by using several static partly transparent “damaged / blocks” images. In combination with the time remap effect and some sound effects.
    Good luck!
  • Corbin Gross
    July 31, 2008 at 2:46 pm
    If you’re using AE there’s three bad TV presets in there. Just type TV into that search bar in the effects panel.
    You might be able to do the blocky distortion by duplicating what ever needs to be distorted and adding a mosaic, some sort of blotchy luminance map (fractal noise or something) and some noise and extra contrast and stuff. Then the time remap would really sell it so the blotchy, blocky layer would be out of sync a little bit.
    Garage Band has some cool promo stingers that sound like somebody looking for a radio station. Those work great for things like the Cloverfield distortion.
