Creating Dailies for MXF DnxHD 36 Metadata not getting copied
Hello all,
I am trying to create a workflow to export Alexa Apple ProRes files to MXF DNxHD 36 as dailies. The caveat here is that the Editorial House is requesting for the original metadata to be embed into the dailies files.
I am using DaVinci Resolve 11 Lite. My settings are as follows:
– On Master Project Settings>Conform Options> Assist Using Reel Names from: Source Clip File PathName (Pattern: */%R.*)
My Export Settings are:
Render Timeline as: Individual Source Clips
Video Format: MXF
Video Codec: DNxHD 36 8-Bit
Video Data Level: Auto
Data Burn in: Same as Project
Save As: Use Source Filename
Render Unique Filenames
Preserve 2 LevelsAccording to all the documents I have read both on AVIDs Website and Blackmagic forums this should work. However if I export a test file and then open it in Resolve again, I can’t see the Reel Name an any additional information on the Shot & Scene options.
Can someone help me identify what am I doing wrong?
Thanks in advance.
Gustavo Jimenez
