Activity Forums Boris FX Creating custom transitions
  • Creating custom transitions
    Posted by Lone Puma on May 5, 2006 at 5:13 pm
    Hi all,
    I am new to using Avid FX (supplied by Boris FX which, I understand, is almost the same as Boris Red).
    I want to create a custom transition, but I am unable to find an explanation on how to do this.
    Does there exist –
    1. A doc which explains how transitions work in Boris FX?
    2. A tutorial?
    I hope that someone will be able to help.
    Peter Mcauley replied 20 years, 3 months ago 2 Members · 5 Replies
  • Peter Mcauley
    May 5, 2006 at 7:14 pm
    Hello,
    You might want to take a look at this section of the BorisFX web site, which explains how to make some interesting custom transitions:
    https://www.borisfx.com/tutorials/burntfilm.php
    I hope this helps.
    Cheers,
    Peter.
  • Lone Puma
    May 6, 2006 at 9:51 am
    Hi Peter,
    Thanks for this. I have already seen and used this tutorial. Quite cool actually.
    However, it didn’t realy help me understand how transitions work, nor did it give sufficient guidance to enable me to create my own.
    Any other pointers?
  • Peter Mcauley
    May 6, 2006 at 6:07 pm
    Hmmm … what type of transition effects are you trying to create? Perhaps I can take you through the steps and with that you will be able to see how these things are generated. Also, there are many tutorial DVD’s which cover this subject – try a google search on Boris Graffiti Tutorial DVD to find them.
    I hope this helps.
    Peter.
  • Lone Puma
    May 8, 2006 at 12:13 pm
    Hi Peter,
    Thankyou for your kind offer.
    I am doing the titles for a theater piece I filmed recently.
    The name of the theater company is Th
  • Peter Mcauley
    May 10, 2006 at 4:13 pm
    Well that should be fairly straight forward. here’s one approach that works:
    starting with an empty timeline …
