Activity › Forums › Adobe Premiere Pro › Creating Countdown Clock
Posted by Wvproducer on January 5, 2006 at 5:49 pmI was just wondering if anyone knew of a program or plug-in that could provide a countdown clock for a lower-third graphic in Premiere. I was hoping to avoid animating it myself, as time is of the essence. Any help would be appreciated. Thanks.
Peter Bailey replied 16 years, 1 month ago 4 Members · 6 Replies -
Craig Howard
January 5, 2006 at 7:32 pmUse the facility already available in PremPro to make a customised Countdown leader and use motion ( scale / position)to set it where you want in the frame.
You can composite it many ways with the tools available.
I made an ID board with a countdown leader, grey scale & bars that I use for all my broadcast masters.
Craig
Shooter Film Company
Auckland
New Zealand(Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
Wvproducer
January 5, 2006 at 7:54 pmSorry, my first post and I should have been more specific. I need to have a timer in the corner of the screen counting down from 5 minutes to zero. The only simple fix I can think of is to videotape a digital clock, and super it over the video, except I haven’t found a clock that will countdown. I was hoping someone knew of a titler program or plugin that could do this…
I’m using Premiere to edit, on Win 2K with Canopus DVstorm2 videocard.
Mike Cohen
January 5, 2006 at 8:20 pmhttp://www.2writers.com/download.htm
this site has a free program which generates an AVI of whatever time code numbers you want. if it works, just make a movie for the time period you want, then reverse it, resize it, make it part of a graphic or whatever
However, this is even better:
I also found a website which has an AVI available for download from 00-60:00:00:00 – which I use for making TC burns in Premiere – you could use that and do the same thing to it.
http://www.mediacollege.com/downloadsvery useful download
Wvproducer
January 5, 2006 at 8:56 pmThanks Mike, i’m downloading the timecode file from mediacollege, I think that will work, and it could be really useful for other stuff.
Craig Howard
January 5, 2006 at 11:24 pmOr you could track down ‘DVdate’ – plugin for PremPro and this will do what you want also very cheaply and efficiently.
Craig
Auckland
Peter Bailey
August 12, 2010 at 6:35 pmI am new to premiere as i am a vegas pro user, where is the countdown clock located in premiere to add to a video?
regards in advance
