Activity › Forums › Adobe Illustrator › Creating Batch Driven Dynamic Text Images
  • Creating Batch Driven Dynamic Text Images
    Posted by Stone Craig on March 24, 2008 at 5:58 am
    Being new to Illustrator I have an immediate need to handle what I understand to be an advanced requirement. Thank you in advance for any information you might be able to provide.
    Here is the challenge:
    I have a new client that has created a base image, that requires a text portion (Text message code) to be changed for each image. We are taking an .eps file of each unique code / image and printing a sign. I am needing to be able to read in the 100 different text codes into a Illustrator template / base image and have the application generate an .eps image for each code. Otehrwise I am stuck entering 100+ codes, saving and moving on the the next manually.
    Any thoughts, tips on how I can make his happen? I have Adobe CS3 suite.
    Best regards,
    Stone Craig
    stone@stonecraig.com
    Bryce Darcy replied 15 years, 9 months ago 3 Members · 2 Replies
  • Ken Latman
    March 26, 2008 at 9:02 pm
    What platform are you on? If your on a Mac you might want to look into Applescript to get this done.
    Windows side you might be able to doe something with VBscript? Not sure on that one.
  • Bryce Darcy
    December 10, 2010 at 3:20 pm
    Stone, did you ever find a solution to automating Illustrator to produce images with variable text? I have precisely this problem. Found your post last night via Google… and then had to have Cow send me a password reminder. Voila. Here I am.
    If anyone else knows how to data drive Adobe Illustrator via a CSV file… any advice would be welcomed!!
    B
