Activity Forums Avid Media Composer Creating an OMF in 1080p/23.976 project
  • Creating an OMF in 1080p/23.976 project
    Posted by Andrew Thompson on March 12, 2009 at 12:28 am
    I’ve just started my first job working in Avid HD project. From what I understand you cannot create OMF’s in this Avid HD realm. A tech I spoke with suggested I temporally change to project to SD, export my embedded OMF, then switch back to HD. Has anyone performed this workflow? Does it work? Are there pitfalls to be aware of?
    thanks in advance!
    AT
    Kris Anderson replied 17 years, 6 months ago 3 Members · 3 Replies
  • Job Ter burg
    March 12, 2009 at 5:30 am
    I’ve heard it was done. However, if you are going to be sending stuff to ProTools, you may just as well create an AAF export rather than OMF, and keep your media in MXF. Works just fine with DigiTranslator on the ProTools side.
  • Andrew Thompson
    March 12, 2009 at 5:08 pm
    Good to know, i’ll give that a shot.
    Thank you.
  • Kris Anderson
    March 12, 2009 at 8:53 pm
    Converting to SD and exporting an OMF from there does work. I did it for a sound studio that was running a Fairlight. No problems.
