Activity › Forums › Apple Motion › Creating an “oil painting” effect in Motion
Posted by Chris Tomkins on January 21, 2010 at 5:38 amHi
I’m trying to make a piece of footage look like an “moving” oil painting – just wondering if people had any ideas for how I could achieve this before I give up and have to buy an expensive plugin.
I’ve tried mixing silks and crystallizing and wide time which is not too bad, but I’m sure there’s a better way…
Cheers
ChrisStephen Smith replied 12 years, 4 months ago 6 Members · 6 Replies -
Arnie Schlissel
January 21, 2010 at 2:10 pmYou may want to try adding an edge detection filter and cranking that way up. Look for “Edges” and “Edge Work”.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Mark Suszko
January 21, 2010 at 2:40 pmI used to use a freeware version of Synthetik StudioArtist for this, but also there are a number of free resources in the Photoshop community where they have created automated batch processes you can apply to the images in a folder. You can download the droplets or specs for free, or make your own, by just turning on the actions recorder while you treat a single frame grab from yuor video to get the look you want, then apply the action to all the frames. Here’s how: Export an image sequence in tif or targa format from your timeline, into a folder. Open that folder in Photoshop and apply the batch action to it, takes just minutes, re-import the stills back into the time line, done. Be sure you pre-set your FCP bins so that graphic imports have a single-frame duration, and I keep these image sequence folders in their own bin. A google search for “photoshop batch actions for oil painting look” will turn up a lot of easy guides to more specifics.
David Bogie
January 21, 2010 at 3:40 pmIf you expect to do this effect more than once ad can bill your clients for the look, you want a package form DigiEffects. https://www.digieffects.com/product_home
They no longer list their products conveniently by platform but most of their plugs now drop into FCP.
bogiesan
Joe Monani
May 13, 2014 at 6:48 amhi, dude, why so complicated, i just brought some pieces oil painting from https://www.oilpaintinggallery.net, they provide good service and do a great job…. you can try and good luck.
JM -
Stephen Smith
May 13, 2014 at 2:28 pm
