Activity Forums Adobe Encore DVD Creating an Invisible button
  • Creating an Invisible button
    Posted by Daniel Christie on October 6, 2008 at 12:39 pm
    Okay, here is what I want to create; a button that is only ever visible when in the highlighted state, so the button jumps from item to item in the menu. My button design is a solid colour, but has a smooth curve, similar to the Nike swoosh. I’ve tried making a button where the swoosh is formatted with (=1) in Photoshop and nothing for the activated and normal states, however, when I build or simulate the menu the edges of my swoosh are very very jaggy and unevenly so. Is this a limitation of the subpicture format or am I doing something wrong? Is there a better way to do this?
    I’m in Encore 2.0
    Many thanks,
    Daniel
    Eric Pautsch replied 17 years, 11 months ago 3 Members · 3 Replies
  • Joe Bowden
    October 6, 2008 at 2:58 pm
    It is a limitation of the subpicture format in DVD-Video. If you can, avoid using curves when designing subpicture layers.
    If you must have the curves, then try also creating a stroke subpicture layer (with a (=2) prefix) and set its opacity to less than the original graphic subpicture opacity. Play around opacities a bit and it should make the jaggies less jarring.
  • Joe Bowden
    October 6, 2008 at 3:00 pm
    Also make sure your subpicture layers have no drop shadows, glows, or softness, if you haven’t already.
  • Eric Pautsch
    October 6, 2008 at 8:20 pm
    Also here’s lifesaving photoshop plug-in I use on all my 8bits.
    https://home.comcast.net/~c.linke/dvdsub/
