Activity › Forums › Compression Techniques › Creating an if-then statement when using FFMPEG
  • Creating an if-then statement when using FFMPEG
    Posted by Chris Zecco on April 29, 2015 at 5:09 pm
    Hey Everyone,
    I was wondering if there was a way to create an IF-THEN statement using FFMPEG for files in a certain directory. For example, I am using FFMPEG to crunch down file sizes of videos to 50MB or lower. I would ideally like to do the following:
    For file sizes in excess of 200MB:
    Encode video bit rate at 1500k
    Encode audio bit rate at 128k
    For file sizes 100-100MB:
    Encode video bit rate at 1100k
    For file sizes less than 100MB:
    Encode video bit rate at 555k
    Is this possible? And yes, I have run tests on individual file to ensure there is no real perceptible quality loss when dropping the bit rates that low.
    Any help that you could give would be amazing, and greatly appreciated.
    – Chris
    2012 Mac Pro
    2x 2.4GHz Intel Xeon
    24GB RAM
    1GB ATI Radeon 5770
    2011 Macbook Pro
    2.4GHz i7
    8GB RAM
    Jim Sustacek replied 11 years, 5 months ago 2 Members · 1 Reply
  • Jim Sustacek
    April 30, 2015 at 6:44 pm
    If the quality is good at the lowest bitrate, why not use the lowest bitrate for all files? 🙂
    I don’t know how to do any if/else switching within FFMPEG, but if you are indeed on a Mac, you could do it with BASH scripting in the Terminal, or even easier, using an Applescript. Save the following Applescript code as an application and then drag your video files onto it. (Edit the FFMPEG command to your liking, of course!)
    -- Drop files on app icon
    on open the_files
    -- Loop through files
    repeat with i from 1 to length of the_files
    -- Get file path
    set the_file to (item i of the_files) as text
    -- Get file size in MB
    set file_size to (size of (info for file the_file)) / 1000000
    -- Set your FFMPEG command base
    set the_command to ("/path/to/ffmpeg -i " & quoted form of (POSIX path of the_file) & " -b:a 128k -b:v ")
    -- Append different video bitrates to your FFMPEG command based on file size
    if file_size is greater than 200 then
    set the_command to (the_command & "1500")
    else if file_size is greater than 100 then
    set the_command to (the_command & "1100")
    else
    set the_command to (the_command & "555")
    end if
    -- Finish your FFMPEG command
    set the_command to (the_command & "k " & quoted form of (POSIX path of (the_file & ".compressed.mp4")))
    -- Run your FFMPEG command
    do shell script (the_command)
    end repeat
    end open
