Activity › Forums › Apple Final Cut Pro Legacy › Creating an Edit Reel
Posted by Milton Ginsberg on December 3, 2012 at 6:26 pmSource material from dvds and dvds off VHS tapes. Need best output for vimeo. What are the best FCP settings for the quality I will need?
Milton Ginsberg replied 13 years, 5 months ago 2 Members · 4 Replies -
Kylee Pena
December 3, 2012 at 8:40 pmYou can check out Vimeo’s recommendations: https://vimeo.com/help/compression
DVDs are standard definition, so you’ll want to transcode that to ProRes before you edit. Then export a master ProRes file, Compress to H264 in Compressor with Vimeo’s specifications.
blog: kyleesportfolio.com/blog
twitter: @kyl33t
demo: kyleewall.com -
Milton Ginsberg
December 3, 2012 at 9:07 pmThanks Kylee. May actually try fcpX with this one. Have to try it some time
and it seems to pull in material in different forms more readily….
something like DVD > HANDBRAKE > MPEG > FCPX in prores
then I’ll check out what form for Vimeo
Sound too complicated? -
Kylee Pena
December 4, 2012 at 1:07 pmI’d use MPEG Streamclip to rip the DVD, Handbrake is kinda wonk and doesn’t make the files you’ll need.
twitter: @kyl33t
Milton Ginsberg
December 4, 2012 at 4:26 pmI’ve become intrigued with fcpX
seems it will take material in any form
quick from MPEG or MP4 from Handbrake.
Now all I have to do is spend a day or two with fcpX tutorials.
