Activity › Forums › Adobe After Effects › Creating an animated deformed mesh – how???
  • Tudor “ted” jelescu
    May 10, 2016 at 2:30 pm
    FreeForm Pro is quite easy to use for that. You can generate the grid in AE on a Layer you use for texture or choose to render the mesh from FF Pro.
    You need the to choose as displacement map a precomp that has the same size as the layer you displace (mesh. Inside the precomp you need to create a animation of shapes in shades of gray that you can use for displacement. Radio Waves with blur for example can generate ripples:
    https://www.youtube.com/watch?v=-U0huO5UO7s
    Tudor “Ted” Jelescu
    Senior VFX Artist
