Activity Forums Adobe Photoshop Creating an action to run on multiple layers
  • Creating an action to run on multiple layers
    Posted by Iann Mcgill on July 27, 2007 at 7:37 pm
    I have let’s say 200 layers. I want to take all of those layers and export them into a single powerpoint presentation or pdf. Is there a way that I can either “file>automate>pdf presentation” and take ALL of the individual layers and send them to the external program. Or do I have to go through every single layer, and “save as” or run the automate on it individually?
    thank you,
    iann
    Iann Mcgill replied 19 years ago 2 Members · 2 Replies
  • Vincent Rosati
    July 30, 2007 at 2:39 am
    Maybe try, Photoshop File/Scripts/Export Layers To Files might work for you? Or, maybe one of the other scripts.
    With Acrobat Pro you can create a multi-page PDF from the batch of resulting images – via the Create PDF button on the menu.
  • Iann Mcgill
    August 6, 2007 at 7:17 pm
    That did work! Thank you! I ended up creating an action to save a .jpg. But I still had to go through and do it one layer at a time manually. This is perfect. Thanks! It will be a great help in the future.
    Now… I don’t mean to press my luck… heh, heh, heh… but I don’t suppose you know of a way, that I can name the layers and then when I use the script you just discussed, I can save the layer by their name?
    Thank you again,
    iann
