Activity › Forums › Adobe After Effects › Creating a Wound
Creating a Wound
Posted by Rojan_man on January 15, 2007 at 6:25 amI have some shots with a character who is supposed to have a two-inch wound on his cheek. What Solid Effects would be good for this? Is there a tutorial that would at least get me started? I need to know if After Effects can pull this off.
Rojan_man replied 19 years, 8 months ago 4 Members · 6 Replies -
Nate Vander plas
January 15, 2007 at 7:34 amThat depends on a number of things, like does the actor turn his head and how close he gets to the camera. Depending on the situation, I think I would probably create a wound with make-up or whatever, photograph it, then cut it out in Photoshop (or AE) and use motion tracking to keep it on the face.
Just out of curiosity, why didn’t they use make-up in production? -
Rojan_man
January 15, 2007 at 3:53 pmI tried cutting out one in Photoshop, and it looks good. I will definitley try the tracking idea. The wound is applied to most of the shots, it was a continuity error that it was not in a few of the takes. Unfortunatly, they are really good takes. If you could point me to tutorials that would enhance my Tracking technique, I would appreciate it.
John Rich
January 15, 2007 at 4:29 pmThis is a little basic, but it might help. jmrser.com and look under tutorials and and the motion tracking one is in the middle.
John Rich
JOHNR
Nate Vander plas
January 15, 2007 at 5:48 pmYou can also check out Andrew Kramer’s tutorial on sky replacement or Aharon’s on cartoonification (the final one). Or just search the forum for motion tracking and read some of the threads.
Mike Clasby
January 15, 2007 at 7:46 pmHere’s all the Tracking Tuts I know of besides the ones already mentioned, the first four are from adobe support. For a step by step on adjusting a track that goes bad (Tracks gone bad! the movie) see the 3rd part of Aharon’s series on turning video into cartoons, there he tracks an eye onto the character, starts at the 5 minute mark. It’s only a 1 point track but he shows you how to adjust frame by frame when the tracker gets cranky. Hope these help.
Track It
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100362&xml=ae65tttrack
Keep motion in perspective
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100241&xml=aft65cornerpin
Using the new Motion Tracker
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=487&xml=aft6ttmotiontracker
Tracking obscured objects in video
https://studio.adobe.com/us/tips/tip.jsp?p=1&id=399&xml=aft6tracking
Aharon’s tut:
movie here:
https://forums.creativecow.net/articles/rabinowitz_aharon/cartoon_look/CC_LiveTrace_Pt_3CD.mov
