Activity › Forums › Adobe After Effects › Creating a watermark
  • Creating a watermark
    Posted by Ian Collister on April 15, 2008 at 7:55 am
    I would like to try to add a watermark to some video casts im doing, think Mtv logo in the corner of the screen!
    What would be the best way of doing this? Would i have to create a graphic in AE, then drop it in as a layer to Premier for my editing? Or the other way around? Edit my footage, then bring it into AE, overlay the watermark, and render it out?
    It doesnt have to animated at the moment, just a static graphic.
    As ever, your collective wisdom is much appreciated.
    Thanks all.
    Ian Collister replied 18 years, 5 months ago 4 Members · 5 Replies
  • Curious Turtle
    April 15, 2008 at 8:28 am
    Why not just create it in Photoshop, and overlay it in Premier? That would be the easiest solution for you.
    Or even just export out a single frame in After Effects, if you don’t have Photoshop. Save yourself the rendering time :o)
    All the best,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Steve Roberts
    April 15, 2008 at 10:34 am
    … and it’s called a “bug” or “logo bug”, at least in North America. 🙂
    https://en.wikipedia.org/wiki/Digital_on-screen_graphic
    https://www.kenstone.net/fcp_homepage/basic_3dlogo.html
    A watermark is placed in the center of the clip, large and obnoxious, to prevent unauthorized usage of the clip. Bugs are in the corner, of course.
  • David Bogie
    April 15, 2008 at 5:28 pm
    Most encoders have a watermark feature. This burns it, at highest possible rez, into the copy that goes out the door. If you place it into the video it will be reduced in size and encoded as pixels in the video instead of being inserted during the encode.
    Each encoder has slightly different rules for size and alpha but most will take any still image format that will support alpha.
    bogiesan
  • Steve Roberts
    April 15, 2008 at 5:59 pm
    Indeed. Ian, if you meant “watermark” and not “bug”, my apologies.
  • Ian Collister
    April 16, 2008 at 8:01 am
    Cheers guys
    It was a Bug that i was after, ill have a look into the encoder tho.
    Thanks again guys.
