Activity Forums Adobe After Effects Creating a template for a photo montage
  • Creating a template for a photo montage
    Posted by Gino Guarnere on November 28, 2006 at 12:53 am
    Hey all,
    I’ve created a quick photo montage that uses 10 photos and a camera that moves through them in 3d space. Very simple. I like the camera moves and everything else I’ve done, but I’d like to be able to use a different 10 photos without redoing the entire montage. Same placement of the photos, everything the same except the photos themselves.
    How do I replace the 10 I’m using for a different 10 without having to recreate the entire composition, camera moves, etc.
    Thank you!
    Gino Guarnere replied 19 years, 9 months ago 2 Members · 2 Replies
  • Steve Roberts
    November 28, 2006 at 1:05 am
    Select a photo in the project window, and cmd/ctrl+H, or file>replace footage, if I recall. It should be the same size as the original image.
    Then repeat. 🙂
  • Gino Guarnere
    November 28, 2006 at 1:11 am
    that should do it! thank you!
