Activity › Forums › Maxon Cinema 4D › Creating a tassel
  • Creating a tassel
    Posted by Inceptdate on August 27, 2005 at 10:07 pm
    I am having some difficulty in creating a tassel (those things on a graduation cap).
    the biggest problem I have is that the individual strands need to lie on and conform to a castle roof (sloped).
    So, I can create individual cylinders and apply a bend object but that is not too accurate and I will be here forever. I tried sweep nurbs – might be the best bet.
    I am not a C4D expert but I am sure there is a better way here. Can’t I have the undividual cylinders automatically conform to the rooftop without haveing to go through a major hassle?
    Thanks in advance!
    Brian Jones replied 21 years, 1 month ago 2 Members · 4 Replies
  • Brian Jones
    August 28, 2005 at 1:39 am
    If you use splines and a Sweep for the strands you could project the splines onto the roof. Clothhilde would be good too (maybe ideal) if you have it.
  • Inceptdate
    August 29, 2005 at 1:16 am
    Thanks for the help… yes, splines would be good- even though I have to create each individual strand and then conform. I have clothilde but have not got into it yet. I am basically looking for a REALLY easy way to create the strands and then have them replicated. I was think of a hair plug-in but i think that would be too crazy.
    Any other thoughts or ideas?
  • Brian Jones
    August 29, 2005 at 4:29 am
    maybe create the tassel with HairDepartmentME then apply clothHilde to droop it.
  • Brian Jones
    August 30, 2005 at 12:40 am
    Here is an example. The tassel (such as it is) was made using HairDepartment and a disk. Squashed a bit after. ClothHilde applied to the ‘strands’. Just go into the Cloth tag’s Dresser tab and click Relax. The strands could use a bit more subdivision or a clothNurb maybe but it’s just an example.
