Activity Forums Adobe After Effects Creating a sunset reflection
  • Scott Carter
    June 28, 2012 at 3:57 pm
    Have you tried using a displacement map on the reflection to match the motion of the water?
  • Victor Camacho guerrero
    June 28, 2012 at 4:53 pm
    thanks Scott I tried to apply the displacement map over this reflect using as reference the lake water layer , however i dont see any improvement.
    any suggestion??
    many thanks
  • Scott Carter
    July 2, 2012 at 4:40 pm
    If you have already tried to experiment with the different displacement map settings (channels and Luminosity) and are not getting results you could try to duplicate the Water footage (and turn the layer off) and boost up the contrast so the displacement effect is more drastic. If you are still not getting results you could also try applying the turbulent displace effect on your reflection and animate the evolution.
    July 4, 2012 at 8:37 am
    Hello Scott, I tried what you said , It improves a little the result which is already a big help.
    thanks a lot.
