Activity Forums Broadcasting Creating a studio with an HDTV monitor on set.
  • Creating a studio with an HDTV monitor on set.
    Posted by Jeremy Saylor on March 20, 2009 at 4:22 am
    I am trying to shoot a TV set with an HDTV on screen. Using a Panasonic AG-HPX170 in 1080i. When I look at the footage on the computer, the TV’s image looks blue and very washed out. Is there anything I can do with the video before hand or with the TV’s settings (A 42′ Sanyo) to make it look better?
    Chuck Reti replied 17 years, 5 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    March 20, 2009 at 12:45 pm
    Choose one of the following (or, likely a combination of two.)
    1- Normal set lighting and white balance and adjust the on-set LCD and/or it’s SOURCES to look natural in that lighting.
    2- Adjust your camera and white balance to match the on-set LCD and gel your lighting to match that. (The set will look ODD to the eye.)
    3- Lock-down most of your shots, and lay-in the video on the on-set LCD using post production effects.
    (You can put a blue or green color on the on-set LCD screen and use a chroma-key in post.)
  • Chuck Reti
    March 21, 2009 at 7:14 pm
    Go into the monitor/tv’s settings menu. There will be a “color temperature” adjustment which should be set to “warm,” to get it just a tiny bit closer to the 3200K color temp of studio lighting. It will probably still look a bit on the blue side but not as badly. Use the Brightness, contrast and Color settings to get image as seen on camera (not to the eye) to look more to your liking.
    If you have access to an in-line color corrector you could adjust RGB balance, levels etc input to the monitor while watching camera video on a scope, and make it nearly perfect. Lacking that you’re limited to whatever control the monitor menu offers you.
    I’ve also done this using a switcher M/E to feed the monitor, doing a linear key with video and generated orange background (or even a slight, simple mix) just enough to take the blue curse off the monitor.
