Activity › Forums › Adobe After Effects › Creating a stream of the same object between to points in AE?
  • Creating a stream of the same object between to points in AE?
    Posted by Oskar Pyke on September 22, 2015 at 8:20 pm
    Hi!
    I’m trying to create a small animated infographic of how the banking system works. I thought I would represent the flow of money between the banks with dollar bills moving along a path. What’s the best way to create an infinite stream of objects along a path that loops indefinitely in After Effects?
    Oskar
    Jens Enqvist replied 11 years ago 3 Members · 2 Replies
  • Kevin Camp
    September 22, 2015 at 10:52 pm
    a simple method would be to use motion tile…
    create a dollar bill graphic in photoshop (or similar) and drop that into a comp, scale that down to about the size you need and then add motion tile to it.
    adjust the output width as needed and then animate the tile center property to make them move. to add a little space between the bills, add grow bounds prior to motion tile.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Jens Enqvist
    September 23, 2015 at 4:04 am
    Sounds like a typical job for Rakka.
    CycoreFX Path Tools
