Activity Forums Adobe After Effects Creating a spinning globe?
  • Creating a spinning globe?
    Posted by Jafar Fallahi on February 19, 2009 at 6:36 pm
    I’m trying to animate a simple globe in a client’s logo. I want to make the globe appear to spin as if the continents were actually on a 3D globe.
    I know that in Illustrator you can create 3d objects and attach symbols on them, but I tried it once and it slowed my computer down (macbookpro) a ton and seemed overly-difficult.
    Anyone have any experience with this type of animation that could recommend a solution?
    Jafar
    Nic Good replied 13 years, 3 months ago 6 Members · 6 Replies
  • Sam Young
    February 19, 2009 at 7:07 pm
    make a layer in a AE comp that’s an image of the world map
    select the layer, then apply effects > perspective > CC Sphere
    in the effect’s controls, animate Y rotation
  • David Bogie
    February 19, 2009 at 8:18 pm
    sphere requires a source layer that is a 2×1 ratio. It wraps perfectly, nothing else does.
    If you’re doing a globe, for crying out loud, be sure you set the rotation properly so the sun rises in th east.
    bogiesan
  • Paul Hennell
    February 19, 2009 at 9:18 pm
    Yep, what others said CC world is what you want. Only reason I’m here is too throw out the Nasa Earth Maps link, which is a great source for your realistic earth globe or a good starting point for tracing your own stylised version.
    (Tip – if you want a seamless globe use the Offset filter in photoshop and edit the sea join so it’s invisible. Faster, cheaper and just as cool as a trip to space(sort of))
    Have fun –
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Travis Roop
    February 20, 2009 at 8:42 pm
  • Jafar Fallahi
    February 22, 2009 at 9:53 pm
    Thanks, that helps a ton. I’ll just animate a map for now and when I get time I’ll go into PS and draw something more appropriate. I’ll try to remember the sun rising in the East, too.
    Thanks again!
    Jafar
  • Nic Good
    June 13, 2013 at 2:45 am
    Hi
    I used CC Sphere to create a globe, using a texture designed for a sphere. However, I can see a small white join line and can’t find a way to get rid of it (even if I add pixels to the texture itself)
    Any suggestions?
