Activity › Forums › Adobe After Effects › Creating a spedometer with GPS-log?
  • Creating a spedometer with GPS-log?
    Posted by Andreas Sweden on August 21, 2005 at 10:19 am
    I have a GPS-log (txt document) would it be possible for AfteEffects to somehow use theese coordinates and that way create a digital speedometer?
    Jens Enqvist replied 21 years, 1 month ago 3 Members · 2 Replies
  • Filip Vandueren
    August 21, 2005 at 10:26 am
    Can you post an excerpt from the txt-file ?
    Dependeing on how easy it is to interpret tha, it should be do-able.
    I’ll take a look at it later. Off to the studio now. So I won’t reply immediately.
  • Jens Enqvist
    August 22, 2005 at 9:10 am
    If you use Garmin MapSource you’ll get the speed and timing from an exported track, no need to calculate it from the coordinates (which can be somewhat tricky).
    Using a spreadsheet program you’ll be able to create text based keyframe data from the log.
    If you can’t find any posts or tutorials on text based keyframe format, do this;
    Create some rotation keyframes in AE, copy them and paste them in a spreadsheet program. You’ll see how to format your GPS speed data to make rotation keyframes. Once you’ve done that you simple copy the text and paste it on a layer.
