Activity › Forums › Adobe After Effects › Creating a solar system
Posted by Betty Boop2 on June 30, 2006 at 12:10 amHi Cowites,
I need to create a solar system that has the planets revolving around the sun. In actuality the sun is the parent company and the planets are its products. I would think 3D layers and layers orient towards camera. But…I’m a bit lost on the workflow of how to set all this up. Any help out there?
Jay Thompson
Thompson Visual Design & Storytelling
7 Marjean Ct.
Kirkwood, MO 63122Betty Boop2 replied 20 years, 2 months ago 5 Members · 8 Replies -
Thehardmenpath
June 30, 2006 at 3:54 amHi. One usual way to make orbits properly is to create a circular mask (better on a solid that fits the comp area) with the circular mask tool. Create it, distort it if you want, select the path and paste it into the position of a (planet) layer. The path will be exactly copied. Make this with all the planets, turn them into 3d layers, and choose what you say, the orient towards camera option. Now create a 3d camera and place it where you want.
For changing the cycle speeds just drag one of the square keyframes. For looping the rotation, create an expression on the position value:
LoopOut(type = “cycle”)
You can see how this very expression is implemented in a tutorial by Aaron Rabinowitz: How to create a flock of birds, part 1.
Steve Roberts
June 30, 2006 at 4:25 amAnother option is to create a null for the center of the solar system and parent a planet to it. You then rotate the null, and the planet orbits it. Repeat for each planet, tilting the null slightly if you wish. Name the nulls appropriately and use coloured layers to keep everything straight.
Ryan Hill
June 30, 2006 at 2:39 pmDepending on how precise you want to be with the orbits being elliptical vs. circular.
If you want to be really precise, employ Kepler’s laws as an expression
https://en.wikipedia.org/wiki/Kepler's_laws_of_planetary_motion#Solution_for_the_motion_as_a_function_of_time -
Ryan Hill
June 30, 2006 at 2:43 pmReally the only benefit of using that formula over an elliptical path or a scaled rotating null, is that the speed of the planet varies over the course of one orbit.
Betty Boop2
June 30, 2006 at 2:55 pmThank you Steve that seems to work quite well. One more question….when the planets orbit around (right to left) they are just fine BUT how get them to apear to go behind the sun and not in front of it. Know what I mean?
Jay Thompson
7 Marjean Ct.
Kirkwood, MO 63122 -
Rob Montague
June 30, 2006 at 2:57 pm -
Steve Roberts
June 30, 2006 at 3:01 pmWell, place the sun where the null is … in the center of the solar system, and make sure all layers have their 3D box checked. Also make sure you have no 2D layers between the 3D layers in the layer stack.
You might want to open up new 3D views to get a different perspective as you work.
And make sure you actually create a camera. Don’t use AE’s default sort-of camera, or you may get messed up down the line.
Betty Boop2
June 30, 2006 at 4:02 pmThanks everybody. Big help!
Jay Thompson
7 Marjean Ct.
Kirkwood, MO 63122
