Activity › Forums › Maxon Cinema 4D › Creating a sloping Arena wall
  • Creating a sloping Arena wall
    Posted by Josey Zadoria on August 31, 2017 at 4:41 pm
    Hello Friends!
    I am trying to create a arena wall where the height is higher on the ends and slopes down to reveal stadium seats. I have tried a sweep nurbs using splines, but no matter what I do it is not giving me the results I want. Meaning it doesn’t come out smooth like the one in the picture below. I know this is probably a simple solution, but I am stuck in trying to figure out. Any tips would be greatly appreciated.
    Jason Mettler replied 8 years, 11 months ago 3 Members · 2 Replies
  • Brian Jones
    September 1, 2017 at 2:49 am
    If I’m understanding correctly then maybe a Loft
    11638_loftwalltest.c4d.zip
  • Jason Mettler
    October 4, 2017 at 7:53 pm
    If you’ve made your object editable, you can select polygon selection—and using the Y axis of the center polygon, push down and the mesh will sag to the middle.
    If you need to stay with primitives, a taper deformer used in the center with proper orientation could do it. Just make sure you have enough polygons for the distortion to be curved and not angled
