Activity Forums Adobe After Effects Expressions Creating a Slider and changing its range via script
  • Creating a Slider and changing its range via script
    Posted by Fabian Brugger on May 9, 2023 at 10:18 am
    Is it possible to change a sliders range, like if you right klick the slider and change set the min and max value, when creating it via a script?
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    for (var p = 0; p < layers.length; p++) {
    layers[p].effect.addProperty(“ADBE Slider Control”);
    Fabian Brugger replied 3 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 9, 2023 at 1:00 pm
    I don’t think there’s any way to do that. An alternative might be to create a pseudo effect, which would allow you to define the slider range and apply the slider via a .ffx file, but you’d have to define the range when you create the pseudo effect, not when you run the script.
  • Fabian Brugger
    May 10, 2023 at 12:09 pm
    Thanks for the quick replay, if you ever in vienna austria ill buy you some beers haha
    I worked around it with just using a linear funktion to translate 0 to 100 into 0 to 360.
    sliderValue = effect(“GlobalOffset”)(“Slider”);
    linear(sliderValue, 0, 100, 0, 360)
    Cheers
