Activity Forums Adobe After Effects Expressions Creating a simple loop
  • Creating a simple loop
    Posted by Mike Derk on November 26, 2007 at 5:37 pm
    I’ve been over in AE Basics trying to get some help with “loopOut()” but I can’t get even this simple expression to do anything. (CS3, G5 Quad Mac)
    All I would like to do is create a simple loop, ten frames long, that plays over and over.
    So far I have:
    1. imported a .mov file, 12fps, and split the layer to get my ten frames, then enabled time remapping, added the loopOut() expression, added a keyframe at the split, deleted the left-most keyframe (leaving only two) and moved the right-most keyframe to the end of the comp. Result: not a change.
    2. Drawn ten frames in Photoshop. Imported them. Lined them up and precomposed them. Brought them into a new comp, or left them in the same comp. Tried time remapping both with a split and without a split. Result: nothing.
    By shoving the keyframes around, I can make time get all screwy, I just can’t get it to loop.
    And, I figure if I can’t do this, I will never be able to use an expression that isn’t aided by the pick whip.
    So, what am I doing wrong?
    Mike
    Mike Derk replied 18 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 26, 2007 at 6:29 pm
    Asumming you wanted to loop the first ten frames – just enable time remapping, set a keyframe at the last frame you want, move forward one frame and set a keyframe with value 0, delete the keyframe on the right, and add a loopOut(“cycle”)expression.
    You shouldn’t need to split the layer.
    Dan
  • Mike Derk
    November 26, 2007 at 9:29 pm
    Ah, this did not work, but I figured it out, so I figured I’d tell you why it didn’t work:
    You: “Asumming you wanted to loop the first ten frames…”
    Actually, I wanted to loop the *only* ten frames (which I didn’t make clear to you). And even if you extend the composition to infinity, once the footage runs out on the given layer, it stops looping.
    So, I had to add to the duration and precompose it (moving all attributes), and then add the loopOut() expression. Then, I could make it repeat ad infinitum.
    So, at the end of the day, you solved the problem. Thanks!
    Mike
