Activity › Forums › Adobe After Effects › Creating a ‘Shy'(hidden) layer through script?
  • Creating a ‘Shy'(hidden) layer through script?
    Posted by Alan Moger on May 7, 2015 at 4:10 pm
    Hey, I’m fairly new to scripting and I’ve scoured the web for this answer and can’t find it, it’s probably something so simple that no-one’s needed to put it out there anywhere, I’ve found in the After Effects Script manual the closest thing being:
    “Layer shy attribute
    app.project.item(index).layer(index).shy
    Description
    When true, the layer is “shy,” meaning that it is hidden in the Layer panel if the composition’s “Hide all shy
    layers” option is toggled on.”
    when paired with:
    CompItem hideShyLayers attribute
    app.project.item(index).hideShyLayers
    Description
    When true, only layers with shy set to false are shown in the Timeline panel. When false, all layers are visible,
    including those whose shy value is true. Corresponds to the value of the Hide All Shy Layers button in the
    Composition panel.
    Which is completely not working for me.
    Anyway, here’s the script so far.
    Thanks in advance!
    app.beginUndoGroup("Hidden Script");
    // Selected Composition
    var comp = app.project.activeItem;
    // Selected Layers
    var slctd_layer = comp.selectedLayers;
    // Create new Solid
    var new_layer = comp.layers.addSolid([0,0,0], "Background", comp.width,comp.height,comp.pixelAspect,comp.duration).trackMatteType = TrackMatteType.ALPHA_INVERTED;
    // Create the letterbox Solid
    var hidden_solid= comp.layers.addSolid([0,0,0], "Hidden", 1920, 817, comp.pixelAspect,comp.duration);
    // if so move the new Layer on top of the selected one
    if ( slctd_layer[0] != null){
    //alert (slctd_layer[0].index);
    new_layer.moveBefore(slctd_layer[0]);
    app.endUndoGroup();
    Alan Moger replied 11 years, 4 months ago 2 Members · 4 Replies
  • Walter Soyka
    May 7, 2015 at 6:50 pm
    You’re trying to make the “Hidden Solid” layer shy?
    hidden_solid.shy = true;
    comp.hideShyLayers = true;
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Alan Moger
    May 7, 2015 at 8:13 pm
    That worked for my next question so thank you for that. Although, I mustn’t have phrased myself correctly, I mean the “hidden layer” needs to be non-visible (the eye icon on the left of it not showing) so that the alpha matte layer below can be seen?
  • Walter Soyka
    May 7, 2015 at 8:15 pm
    Ah, that’s not what “shy” means. Shy layers are hidden in the UI when the comp shy switch is enabled.
    The property you’re asking is about is “enabled.”
    hidden_solid.enabled = false;
    Walter Soyka
  • Alan Moger
    May 7, 2015 at 8:17 pm
    That is absolutely perfect, thank you very much. I was toying around with the wrong property- that being ‘Visible’ silly me.
