Creating a Shape Path Tween
Hi Guys,
It’s been a long time since I posted here!
Imagine I had two shape paths with the same number of points.
Is it possible, using the path property expressions, to create a third shape which is always a halfway morph between shape one and shape two?
I have tried using keyframes and the .path.valueAtTime property, but the in-between path always “catches up” with the second shape, whereas I want it to remain a 50% tween between shape one and shape two, no matter how I alter shape two.
Here’s a frame of what I want to acheive:
Shape one is the straight “F”. Shape two is the outer shape. Shape three should remain 50% between shape one and shape two even if I alter shape two over time.
I hope this makes sense!
Thank you,Jason Guest
