Activity Forums Adobe After Effects Creating a Set First Vertex Keyboard shortcut for a Mask
  • Creating a Set First Vertex Keyboard shortcut for a Mask
    Posted by Nikhil Tanenquin on April 22, 2014 at 4:59 am
    I have been using AE for about 10 years now so know my way around the software. Although not very strong on technical side of it. I was trying to create a keyboard shortcut for this pull down menu
    Layer > Mask and Path Shape > Set First Vertex
    I went through a few tutorials of how to modify the Keyboard Shortcuts text documents, no luck. Also installed the KeyEd Up.jsx and still no luck.
    I thought surely there would be someone on this forum who would know. Thanks in advance.
    Nikhil
    Roland R. kahlenberg replied 12 years, 5 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    April 22, 2014 at 6:02 am
    There is no built-in shortcut key for selecting/applying a First Vertex. Can KeyEd Up.jsx link a user-created shortcut to a menu item?
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Adobe After Effects CC ACE/ACI
    Imagineer Systems (mocha) Certified Instructor
  • Nikhil Tanenquin
    April 22, 2014 at 8:59 pm
    I figured it out, I went in to the txt file and made changes to the script.
    Under [“CSwitchboard”]
    “MaskSetFirstVertex” = “(Ctrl+Shift+Alt+M)”
    Then save the txt file and restart AE, the last step is what I overlooked. So its all good now.
    Nikhil
    April 24, 2014 at 12:54 am
    Many thanks for reporting back. 🙂
    HTH
    RoRK
