Activity › Forums › Compression Techniques › Creating a seamless 10s h.264 loop for HTML5
  • Creating a seamless 10s h.264 loop for HTML5
    Posted by Pay Bas on November 26, 2013 at 11:15 am
    Hi all, I’m wondering if someone could give me some imput on how to best encode a 10s (30fps) video loop in h.264 so that it loops smoothely in HTML5 containers. So far the results have been a very mixed bag, and I want to keep the filesize as low as possible. My biggest problem is the noticable “jump” when the loop happens, as if the new keyframe pops in. Because the animation contains smoke, there is a noticable stutter in clarity, which only goes away when push the VBR significantly higher (which I want to avoid due to filesize).
    Any and all input is welcome.
    General
    Complete name : 1.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 492 KiB
    Duration : 10s 0ms
    Overall bit rate : 403 Kbps
    Encoded date : UTC 2013-11-25 11:13:11
    Tagged date : UTC 2013-11-26 11:14:30
    Writing application : Sorenson Squeeze
    Comment : Encoded by
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L5.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 16 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 10s 0ms
    Bit rate mode : Variable
    Bit rate : 400 Kbps
    Width : 368 pixels
    Height : 590 pixels
    Display aspect ratio : 0.624
    Frame rate mode : Constant
    Frame rate : 30.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.061
    Stream size : 487 KiB (99%)
    Writing library : x264 core 129
    Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=0 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=400 / ratetol=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Tagged date : UTC 2013-11-25 11:13:11
    Pay Bas replied 12 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
