Activity Forums Adobe Illustrator Creating a rope brush with a gradient mesh object
  • Creating a rope brush with a gradient mesh object
    Posted by Dave Reyburn on September 20, 2012 at 4:54 pm
    I have been struggling to re-create this rope. I tried to make a brush, but since it contains a gradient mesh I am unable to do so. Can someone please help??
    Tylor Larson replied 13 years, 11 months ago 2 Members · 1 Reply
  • Tylor Larson
    September 20, 2012 at 10:55 pm
    here is what i would do. if it is just for a logo that i need to create just one time.
    can you create the brush for the rope? don’t worry about the gradient just yet … just get the shape right and then expand the brush and the off set the paths with a really small negative value. then make the offset path a light yellow and the original path orange… then do a blend shape between the two.. i don’t have time to test this but you might need to regroup the paths.
    also here is a link to some free illustrator brushes that should help you trouble shoot your problem in case having the gradient as part of the brush is critical.
    https://www.tripwiremagazine.com/2012/05/illustrator-brush-sets.html
