Activity › Forums › Adobe After Effects › Creating a Random Moving Mask Shape…? (or something like that)
  • Creating a Random Moving Mask Shape…? (or something like that)
    Posted by Erin Shelby on April 23, 2006 at 10:54 pm
    Basically, if it was possible, I’d like to create a mask shape with 6 sides and then “wiggle” the points position to my customization. Yet I know controlling points directly with an expression is impossible (?), but generally I want that type of control. I tried it with Bezier warp, but it actually warps it and I would like it to retain the hard corners like moving mask points does…does anyone know what combination of effects could get me close to figuring this problem out?
    (ps: a bunch of nulls with the Beam effect will not do as well, because I need the middle of the shape filled)
    Erin Shelby replied 20 years, 5 months ago 2 Members · 2 Replies
  • Mike Clasby
    April 24, 2006 at 12:51 am
    This might work from
    Date: Feb 27, 2006 at 8:11:34 am
    Subject: Re: 4 free point mask tool
    I made a script that puts a tracker data into a mask vertex, check it out here:
    https://www.aenhancers.com/viewtopic.php?t=329
    And this from crgreen:
    https://www.crgreen.com/aescripts/
    Connect_Vertex_to_Point.jsx
    Allows the animation of individual mask vertices by “linking” a vertex to any two-dimensional point property
    (like position, track point attach point, “point” expression control, etc).
    Date: Feb 16, 2006 at 5:11:57 pm
    Subject: Re: Any way to control a mask with tracking data?
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=871496
    You’d have to create your wiggly data first, then you could apply it to your mask via his script. I haven’t done this but it should work and you should have enough info to figure it out or to do a better advanced search.
  • Erin Shelby
    April 24, 2006 at 6:23 pm
    oh, wow
