Activity Forums Apple Final Cut Pro Legacy Creating a “phone call” quality to recorded audio
  • Creating a “phone call” quality to recorded audio
    Posted by Sean Meehan on February 10, 2009 at 3:57 am
    Hello all,
    I’ve recently recorded some VO for my student film, and I want to make it into a convincing voicemail message. I just want the recorded VO to sound like a phone call or voice mail, and I’m sure there’s a quick and easy way to do it, but when I used the High Pass Filter (I think it was High Pass anyway), it made it passable, but somewhat incomplete. Any suggestions?
    Michael Gissing replied 17 years, 7 months ago 3 Members · 2 Replies
  • Jared Smith
    February 10, 2009 at 6:39 am
    do you have access to soundtrack pro? there are some sweet filters in there that should be able to help you out!
  • Michael Gissing
    February 10, 2009 at 7:46 am
    An old trick we used to do was feed the sound through headphones and then mic the headphones to re-record that tinny small speaker sound.
    These days, I use a convolution reverb with a phone impulse sample. using EQ, use both high pass (set to about 600hz) and a low pass (set to about 4khz). Also a lot of compression helps as well.
