Activity › Forums › DVD Authoring › Creating a Music Video DVD from different format/size files
  • Creating a Music Video DVD from different format/size files
    Posted by Zoe Elliott on March 23, 2011 at 9:58 am
    Hi All,
    I have a selection of music videos on a hard drive that someone has asked me to make into a DVD for them. Unfortunately, the videos are all different sizes and formats -some NTSC, some PAL- and I really have no idea where to begin. I have access to Toast, DVD Studio Pro and MPEG Streamclip, but limited knowledge of the programs.
    Should I convert all the videos to the same size/format first? And, if so, what compression and which program should I use?
    NB: Not sure they’re that bothered about menus/chapter marks etc, they just want a playable DVD.
    Sorry for the newbie questioning, any help gratefully received!
    Zoe.
    Michael Pfost replied 15 years, 6 months ago 3 Members · 2 Replies
  • Daniel Ludwig
    March 23, 2011 at 1:55 pm
    hi zoe,
    if you need to create a DVD, you need to ask the client if he needs PAL or NTSC, both can´t be done on one disk by spec, and of course you need to transfer the other material.
    if your clients recommendation is PAL you need to format-convert the NTSC-files and wise versa.
    cheers
    danny
  • Michael Pfost
    March 23, 2011 at 3:46 pm
    I would convert everything to the same format and size. I had to create a h.264 clip at 1080p and had a dozen different image sizes and codecs. I just converted everything to the same and it made editing easy.
    If they need PAL — then convert everything to PAL first. If they need NTSC — then go that route. It will make your life easier.
