Activity Forums Apple Motion Creating a motion path to follow a write-on behavior
  • Creating a motion path to follow a write-on behavior
    Posted by Jeffrey Williams on January 26, 2010 at 6:25 pm
    This feels like it should be obvious, but I’m having brain lock.
    I’m using the ‘write on’ effect to draw an outline around a block of text and I’m trying to create a burning fuse effect, and I want my sparkly particle emitter to follow the head of the write on behavior. Is there an easy ‘match move’ behavior that will do this, or do I have to do it the old-fashioned way by animating it by hand?
    Jeffrey Williams replied 16 years, 8 months ago 2 Members · 4 Replies
  • Mark Spencer
    January 26, 2010 at 6:29 pm
    Assuming your write-on effect is using a bezier shape as the path to follow, just apply a motion path behavior to the emitter and use the same shape as the source.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jeffrey Williams
    January 26, 2010 at 6:38 pm
    Thanks, Mark. Just finished working through your Motion 4 book, by the way… that’s why this really feels like some idiotic brain lock!
    Is there a way to copy the bezier shape from the object to the bezier shape of the motion path? I was looking for one of those ‘wells’ to drag the shape into, but couldn’t find. All the ‘motion path’ behavior offers is a drop down menu.
  • Mark Spencer
    January 26, 2010 at 6:47 pm
    When you apply the motion path behavior to the emitter, in the Inspector, change the path to Shape, then you’ll see the well to drag your shape into.
    Mark Spencer
  • Jeffrey Williams
    January 26, 2010 at 6:53 pm
    Bingo! I knew it was something obviously simple like that. Thanks!
