Activity › Forums › Adobe After Effects › creating a mony calculator from numerical data in text layers
  • creating a mony calculator from numerical data in text layers
    Posted by Christy Lindsay on August 25, 2010 at 10:19 am
    I need to create a text layer that gets its value from adding the amounts of other text layers together. Like in a exl spread sheet.
    Is this possible. Working out percentages would also be a help.
    Cheers,
    Christy
    John Cuevas replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    August 25, 2010 at 2:02 pm
    If this is possible(not sure if it is, numbers are really just ASCII text)the person to ask is Dan Ebberts in the Expressions forum.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • John Cuevas
    August 25, 2010 at 7:13 pm
    Actually came up with a way that sort of works, adding sliders to the text layer.
    Create a blank text layer(cntl+alt+shift+t) and add a slider. Add this expression to source text “Math.round(effect(“Slider Control”)(“Slider”))”
    Duplicate text layer.
    Make your sum text layer, and add the following expression to source text:
    a = thisComp.layer(” 3″).effect(“Slider Control”)(“Slider”);
    b = thisComp.layer(” 2″).effect(“Slider Control”)(“Slider”);
    a + b
    Basically instead of trying to convert the ASCII text, I’m getting my numbers from the slider. I just used the pick whip for the entire operation.
