Activity Forums Avid Media Composer creating a Matte
  • creating a Matte
    Posted by Dan Crouch on September 30, 2014 at 3:27 pm
    Hello all,
    I am cutting a scene whereby the main character is driving a car at night.
    It is shot from the passenger seat across the car, his face is in profiler, his door window to his left as he drives is black.
    I have some archive shots of roads at night, lights, street signs etc that I would like to super impose onto the black window and would like to create a matte to do so.
    Can anyone give me some basic advise on how to do this.
    It is an offline edit so doesn’t have to be top spec, just a guide so any really basic help would be very much appreciated.
    Cheers,
    Dan.
    Scott Cole replied 11 years, 11 months ago 2 Members · 4 Replies
  • Scott Cole
    September 30, 2014 at 3:49 pm
    You can use the Animatte effect, under the Key category in the effects palette. Either image can be on the upper track, just draw your keyshape, for lack of a better term, and then choose “Key In” or “Key Out” till you get the effect you desire. With Animatte, you can create multiple key objects, move them independently, and you can feather the edges.
    M. Scott Cole
    Senior Post Production Editor
    60 MINUTES
    CBS News, NYC
    sc6@cbsnews.com
    mscottc@comcast.net
  • Dan Crouch
    September 30, 2014 at 4:18 pm
    Brilliant Scott, worked first time.
    Thanks v much!
    Cheers
    Dan.
  • Dan Crouch
    September 30, 2014 at 4:25 pm
    Hi Scott,
    Does it matter which clip goes on which video layer?
    I put the archive on V 1 and the car window shot on V2 and swapped sources.
    Dan.
  • Scott Cole
    September 30, 2014 at 5:14 pm
    In this case, no, just either swap sources or change the “key in, Key out” selection. It may make a difference in more complicated cases.
    M. Scott Cole
    60 MINUTES
    CBS News, NYC
    sc6@cbsnews.com
    mscottc@comcast.net
